The term global indicates characteristics or features effecting the system as a whole. Use the Global Configuration Mode to configure the system globally, or enter specific configuration modes to configure specific elements (such as interfaces or protocols). Use the configure terminal command (under PRIV EXEC) to enter the global configuration mode.
The following example describes the process of entering the global configuration mode from the privileged EXEC mode:
<DEVICE>#configure terminal <DEVICE>(config)#
The system prompt changes to indicate you are now in the global configuration mode. The prompt consists of the device host name followed by (config) and a pound sign (#).Commands entered in the global configuration mode update the running configuration
file as soon as they are entered. However, these changes are not saved in the
startup configuration file until a commit → write → memory
command is issued.
<DEVICE>(config)#? Global configuration commands: aaa-policy Configure a authentication/accounting/authorization policy aaa-tacacs-policy Configure an authentication/accounting/authorization TACACS policy alias Alias ap410 AP410 access point ap460 AP460 access point ap505 AP505 access point ap510 AP510 access point ap560 AP560 access point ap621 AP621 access point ap622 AP622 access point ap650 AP650 access point ap6511 AP6511 access point ap6521 AP6521 access point ap6522 AP6522 access point ap6532 AP6532 access point ap6562 AP6562 access point ap71xx AP71XX access point ap7502 AP7502 access point ap7522 AP7522 access point ap7532 AP7532 access point ap7562 AP7562 access point ap7602 AP7602 access point ap7612 AP7612 access point ap7622 AP7622 access point ap7632 AP7632 access point ap7662 AP7662 access point ap81xx AP81XX access point ap82xx AP82XX access point ap8432 AP8432 access point ap8533 AP8533 access point application Configure an application application-group Configure an application-group application-policy Configure an application policy association-acl-policy Configure an association acl policy auto-provisioning-policy Configure an auto-provisioning policy bgp BGP Configuration ble-data-export-policy Configure a ble data export policy bonjour-gw-discovery-policy Bonjour Gateway discovery policy bonjour-gw-forwarding-policy Bonjour Gateway forwarding policy bonjour-gw-query-forwarding-policy Bonjour Gateway Query forwarding policy captive-portal Configure a captive portal clear Clear client-identity Client identity (DHCP Device Fingerprinting) client-identity-group Client identity group (DHCP Fingerprint Database) clone Clone configuration object crypto-cmp-policy CMP policy customize Customize the output of summary cli commands database-client-policy Configure database client policy database-policy Configure database policy device Configuration on multiple devices device-categorization Configure a device categorization object dhcp-server-policy DHCP server policy dhcpv6-server-policy DHCPv6 server related configuration dns-whitelist Configure a whitelist event-system-policy Configure a event system policy ex3500 Ex3500 device ex3500-management-policy Configure a ex3500 management policy ex3500-qos-class-map-policy Configure a ex3500 qos class-map policy ex3500-qos-policy-map Configure a ex3500 qos policy-map ex3524 EX3524 wireless controller ex3548 EX3548 wireless controller firewall-policy Configure firewall policy global-association-list Configure a global association list guest-management Configure a guest management policy help Description of the interactive help system host Enter the configuration context of a device by specifying its hostname igmp-snoop-policy Create igmp snoop policy inline-password-encryption Store encryption key in the startup configuration file iot-device-type-imagotag-policy Configure a iot imagotag device type policy ip Internet Protocol (IP) ipv6 Internet Protocol version 6 (IPv6) ipv6-router-advertisement-policy IPv6 Router Advertisement related configuration l2tpv3 L2tpv3 tunnel protocol location-policy Configure a location policy used for ExtremeLocation mac MAC configuration management-policy Configure a management policy meshpoint Create a new MESHPOINT or enter MESHPOINT configuration context for one or more MESHPOINTs meshpoint-qos-policy Configure a meshpoint quality-of-service policy mint-policy Configure the global mint policy nac-list Configure a network access control list netflow-policy Configure a Netflow policy no Negate a command or set its defaults nsight-policy Configure a Nsight policy nx45xx NX45XX integrated services platform nx5500 NX5500 wireless controller nx65xx NX65XX integrated services platform nx75xx NX75XX wireless controller nx9000 NX9000 wireless controller passpoint-policy Configure a passpoint policy password-encryption Encrypt passwords in configuration profile Profile related commands - if no parameters are given, all profiles are selected purview-application-group Configure a Purview application-grou purview-application-policy Configure a Purview application policy radio-qos-policy Configure a radio quality-of-service policy radius-group Configure radius user group parameters radius-server-policy Create device onboard radius policy radius-user-pool-policy Configure Radius User Pool rename Clone configuration object replace Replace configuration object rest Configure the url to send the real time RSSI feed to rf-domain Create a RF Domain or enter rf-domain context for one or more rf-domains rfs4000 RFS4000 wireless controller rfs6000 RFS6000 wireless controller rfs7000 RFS7000 wireless controller roaming-assist-policy Configure a roaming-assist policy role-policy Role based firewall policy route-map Dynamic routing route map Configuration routing-policy Policy Based Routing Configuration rssi-interval-duration Configure the periodicity of sensding RSSI info from sensor to server rtl-server-policy Configure a rtl server policy schedule-policy Configure a schedule policy self Config context of the device currently logged into sensor-policy Configure a sensor policy smart-rf-policy Configure a Smart-RF policy t5 T5 DSL switch url-filter Configure a url filter url-list Configure a URL list vx9000 VX9000 wireless controller web-filter-policy Configure a web filter policy wips-policy Configure a wips policy wlan Create a new WLAN or enter WLAN configuration context for one or more WLANs wlan-qos-policy Configure a wlan quality-of-service policy write Write running configuration to memory or terminal clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode revert Revert changes service Service Commands show Show running system information <DEVICE>(config)#
